Regarding this callback function in the ds-example plugin, is it only called whenever there is an inflow of data? Or is it only called when there is an inference result?
* Called when element recieves an input buffer from upstream element.
static GstFlowReturn
gst_dsexample_transform_ip (GstBaseTransform * btrans, GstBuffer * inbuf)
These are two same scenarios. It’s called when there is a gstbuffer through. The data and inference result are binding with gstbuffer.
