With the multi-model feature of deepstram-app, can the data flow continue if the second model is not detected based on the classification of the first model?
I actually want to perform serial classification detection of two independent engine models.
please refer to /opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt, the first model will do detection, the latter models will do color, maker, type classification respectively.
Yes, I have tested this case, but he is secondary detecting the main classification. For example, the vehicle is detected, and then the second model detects the color of this vehicle.
What I want is that the second model and the first model are independent, for example the first model detects the vehicle and the second model detects the person.
yes, you can modify the sgie’s configuration, use a detection model, set network-type
to 0, set process-mode to 1.
