ODMDATA is programed through the flash process, it’s store there and should be exist after OTA.
nevertheless, it’s nvidia-l4t-bootloader, which include the common library API for getting ODMDATA.
thanks
Thanks ,I misunderstood at first. Is there any other ways that can change ODMDATA except through flashing process.
Is there any API that I can change ODMDATA rather than just only getting ODMDATA?
Hundreads of devices (TX2-4G jetpack4.4) have been installed in several project. If reflashing the device is only way to change the ODMDATA. It will cost too much because we have to remove them from projects .
The reason why I need to enable PMIC-WDT is that our team want to slove the problem mentioned in following post.
After enabling PMIC-WDT ,the test result looks well.At least, that probelm didn’t happen again so far.
It need to be solved as soon as possible and it is urgent.
Any help will be appreciated.
Or is there other way to enable PMIC-wdt and disable Tegra-WDT ? For example ,After getting the ODMDATA, whether the setting enabling PMIC-WDT or not,the bootloader or something else force to enable PMIC-WDT.
In other words,ODMDATA only provide setting.but there are something else to read ODMDATA and enable PMIC-WDT.
