Hi group,
I know that docker containers are for building from pieces not copping files between them but is it possible to copy triton module from container openai-triton to container stable-diffusion-webui ???
Thank you,
tj
Hi group,
Thank you,
tj
Yes, it is possible to copy files between Docker containers, including the Triton module from the openaitriton container to the stablediffusionwebui container.
Docker containers are designed to be isolated from each other, but there are ways to share files between them. Here are a few approaches:
triton-module and mount it to both containers:docker run -d --name openaitriton -v triton-module:/triton-module openaitriton
docker run -d --name stablediffusionwebui -v triton-module:/triton-module stablediffusionwebui
Then, you can copy the Triton module from the openaitriton container to the shared volume:
docker exec -it openaitriton cp /path/to/triton/module /triton-module/
Finally, you can access the Triton module from the stablediffusionwebui container:
docker exec -it stablediffusionwebui ls /triton-module/
docker cp command to copy files between containers. For example:docker cp openaitriton:/path/to/triton/module stablediffusionwebui:/path/to/triton/module
This will copy the Triton module from the openaitriton container to the stablediffusionwebui container.
3. Dockerfile: You can also create a new Docker image that includes the Triton module by using a Dockerfile. For example:
FROM openaitriton
COPY /path/to/triton/module /triton-module/
Then, you can build the new image and use it to create a container:
docker build -t my-image .
docker run -d --name stablediffusionwebui my-image
In summary, while Docker containers are designed to be isolated, there are ways to share files between them. You can use volume mounting, docker cp, or create a new Docker image to copy the Triton module from the openaitriton container to the stablediffusionwebui container.
Note that the Jetson AGX Orin Developer Kit uses Docker containers to manage software dependencies and provide a consistent development environment. The openaitriton and stablediffusionwebui containers are likely used to provide specific software dependencies and environments for AI and machine learning applications.
Usually, you can install the extra files on either one as a base image.
Could you share why you need to do this?
Ideally, you can install Triton module on the stable-diffusion-webui image.
Hi Aasta,
I just want to run project Hi3DGen (converts images to 3d mesh)
So, I need to run all together following modules
torch, torchvision, diffusers, gradio, accelerate, spconv, triton, transformers, xformers
looks that it is impossible to collect them on jetpack 6.0 agx orin in versions which let them work all together…
for example now i collected all modules on image stable-diffusion-webui but xformers gives an error
transformers ModuleNotFoundError: No module named ‘triton.ops’
So, I though that maybe if compiling of some package version is immpossible i just copy it from other container.
( in this case, because i can compile only last release of triton but i’m unable to compile older releases. so, i thought that maybe copying old version of trition package form openai-triton image could solve the problem.)
Thank you
tj
Most of the packages you need are supported in the link below:
Maybe you can try to set up locally or create a new container based on a standard Ubuntu image?
