TJCUT
1
I am developing with NX.
Get the YUV image of the camera with the following command:
SENSOR_ID=0
WIDTH=3840
HEIGHT=2160
gst-launch-1.0 v4l2src device=/dev/video$SENSOR_ID \
! "video/x-raw, format=(string)UYVY, width=(int)$WIDTH, height=(int)$HEIGHT" \
! multifilesink location=/tmp/%d.yuv max-files=100 -e
Is it possible to extract only Y Data with GStreamer options?
The format of single Y plane is GRAY8 so you can extract the pane through videoconvert plugin:
! videoconvert ! "video/x-raw, format=(string)GRAY8" \
system
Closed
5
