Hi, I want to flash Jetson Orin Nano / Orin NX (JetPack 6.2) and TX2 (JetPack 4.6) modules, but I would like to avoid using the USB recovery cable. The USB port is not easy to reach in our setup, but ethernet is.
- Is flashing over Ethernet possible at all?
- Would a USB-to-Ethernet or USB-C-to-Ethernet adapter/bridge help here, or does recovery mode only work on the real USB port? Is there any way to do it?
- If direct Ethernet flashing is not possible, what is the closest supported option?
If you are talking about a full flash, then it must have USB connected when under recovery mode.
If the devices are already bootable, OTA or targeted software updates over Ethernet would be the most practical alternatives. However, initial flashing, full reflashing and recovery of unbootable devices would still require USB access through NVIDIA’s standard flashing procedure.
Regards,
Carolina Trejos
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
(Disclaimer: Assistance generated with AI support for Jetson flashing architectures).
Directly flashing a completely uninitialized Jetson module entirely over Ethernet is not possible for the initial setup.
Here is why, along with best practices for remote hardware:
1. Why Initial RCM Flash Requires USB
Boot ROM Limitations: When entering Force Recovery Mode (RCM), control sits in the hardware Boot ROM, which does not have a network stack, TCP/IP, or DHCP.
USB Endpoint Requirement: The Boot ROM relies strictly on direct low-level USB control endpoints (VID 0955:7026) to receive initial bootlets (nvtboot, MB2). USB-to-Ethernet adapters will not work.
(Note: Even NVIDIA’s l4t_initrd_flash.sh network-assisted flashing requires an initial physical RCM connection to boot the initrd kernel).
2. Workarounds for Remote Deployments
If your modules are in sealed or inaccessible enclosures, engineers use these standard architectures:
Post-Flash OTA Updates: Once flashed once via USB, you never need USB again. All subsequent kernel, device tree, and rootfs updates can be done 100% over Ethernet using NVIDIA’s OTA tools or apt.
Remote Recovery Hardware: For hard-to-reach enclosures that might require a brick recovery, design your carrier board with an onboard MCU or IoT relay wired to the Jetson’s physical Recovery and Power/Reset pins. This lets you pull the recovery pin LOW and pulse power programmatically over the network, or use a network-managed IP-USB switch.
