I am using this guide to run YOLO tiny on the Jetson :
But I would like to get the result of the intermediate layers. Wondering if that would be possible.
We can set the layer as a network output and bind a buffer to it to collect the output.
We cannot do it while loading. We need to set the layer as a network output and regenerate the engine.
Thank you.
Thank you!
But any idea how I can do that? Like a guide or something? I am new to machine learning and trying to learn new stuff
Basically, I want to get outputs of all the layers and save them to a file to see whats inside.
Currently, we do not have exact resources to share.
You can check out the following, hope they are helpful.
Thank you.
I am using YOLO_to_ONNX and then ONNX_to_TensorRT.
So, can we do this with an existing model or do we need to create our own model?
You can try modifying the ONNX model and re-generate the TensorRT engine.
