• Hardware Platform Jetson Xavier NX • DeepStream Version deepstream:6.3-triton-multiarch • JetPack Version (valid for Jetson only) R35 release (I’m not sure which version it’s correspond to) • Issue Type( questions, new requirements, bugs) Question • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) As displayed below.
Greeting everyone.
I’m just curious: is it possible to get the unused unique ID from the nvtracker plugins?
For example, in the first few frames, I have unique IDs 1, 2, 3, and 4 for each person in the frames. Then, after a while, one person leaves the frames, and the unique IDs that are left are 2, 3, and 4. I was wondering whether it was possible to get the unused unique ID (1 in this case) or if I needed to write some functions to keep track of the unique ID myself.
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Why you need the past tracker ID? nvtracker will re-asign the past ID to the person 1 if the person enter the video again.
I’m currently developing some applications that utilize deepstream with some microservices on the cloud. In one part of the application, I need to implement some kind of function to inform microservices that some particular person (based on tracker ID) no longer exists in the frames. Currently, I maintain the list of existing people by using struct, and I’m just curious whether the nvtracker is keeping track of this or not.
