Is it possible to install AODT on the 4090 or 5090?
Does the backend only support RTX 6000 Ada, L40, A100, and H100?
Sorry for the late reply. Backend only support RTX 6000 Ada, L40, A100, and H100, not 4090/5090
We are able to use the backend normally with the RTX 6000 Ada. Thank you for your response. May I ask if DGX Spark will be supported in the future?
AODT on DGX Spark is still under discussion.
