Is it possible to make a dtb file to be used in jetson nano emmc module using jetson nano module pinmux template excel file?
If possible, how should I edit the following excel file?
Thank you.
Thank you.
Already taught you 2 years ago when running pcm3010… The things are same but just different pins.
