Is it possible to monitor the boot process for Jetson NRU-220s using Minicom or other tool connected via USB?
I’ve connected my Ubuntu 22 host to nru-220s-nvidia-jetson-orin via a USB-A to USB-C cable. I used Minicom to connect to /dev/ttyACM0, and that works OK. I can also connect via SSH, so this usb connection does not bring anything new.
I’d like to use Minicom (or other tool) also to monitor the Jetson boot process - is this possible at all? While booting, there is no /dev/ttyACM0 yet, nothing to connect to.
Hi danijel.domazet,
It seems you are using a custom carrier board from NEOUSYS.
You should be able to check the full serial console log through /dev/ttyACM0 from your host.
Please share your full boot up log for further check.
