• Hardware Platform (Jetson / GPU) : jetson
• DeepStream Version : 5.1
• JetPack Version (valid for Jetson only) : 4.5
• TensorRT Version : 7.1.x
I have a three custom elements gstreamer in the pipeline, the first one is remove some object-metadata user-metadata and the second element is tracker and the last is get usermetadata and put them in the object metadata again,
My purpose is that I don’t want to tracker follows up some objects and for this I have to put those object metadata in user-metadata then remove them, So in the last element capture those metadata from user-metadata then put them in new object-metadata.
The main pipeline is like this:
… > first_element > tracker > last_element > …
First of all, I want to know is it possible to do this way?
snippet code for first element : I used from this repo.
user_meta = pyds.nvds_acquire_user_meta_from_pool(batch_meta) if(user_meta): user_meta.user_meta_data = obj_meta; user_meta.base_meta.meta_type = pyds.NvDsMetaType.NVDS_OBJ_META pyds.user_copyfunc(user_meta, meta_copy_func) pyds.user_releasefunc(user_meta, meta_free_func) pyds.nvds_add_user_meta_to_frame(frame_meta, user_meta)
if I put object metadata in user-metadata, like this :
user_event_meta.user_meta_data = obj_meta
Is it possible to receive all of properties of object-metadata like object_id, rect_params.top, rect_params.left, … from user-metadata in the last element?
