Hi! I’m hoping to run EtherCAT on the Ethernet interface on TX2. I saw that EtherCAT can be supported on any Ethernet MAC. However, it has never been reported if anyone succeeded or failed to do so. So I was wondering if it is possible to run EtherCAT on TX2.
Thank you!
Bocheng
Almost a duplicate of:
https://devtalk.nvidia.com/default/topic/1025743/jetson-tx1/is-it-possible-to-run-ethercat-on-tx1-/
(the other URL is for a TX1, but same question)
See the other URL…I used a TX2 under L4T R28.1 for a simple test which seems to imply EtherCAT will work for the R28.1 release (probably for other releases as well, I haven’t tested).
