Is it possible to send frames with a configuration file?
Jetson Orin Nano 8GB
• DeepStream Version
7.1
6.1
• TensorRT Version
10.3
Hello everyone
I’m currently working on a patrolling/signalling system using the DeepStream SDK, a camera, and a robot. For communication, I’m using MQTT as the protocol, and my goal is to send a frame every time a detection is made.
In a traditional .cpp or .python workflow, I would convert the frame into a Base64 string and send it over MQTT. However, I’ve found that using configuration files (the ones executed via deepstream-app -c your_config_file.txt) offers a more maintainable and straightforward approach for my use case. I’d like to continue using this configuration-based method, but I’m not yet clear on how to send customized frames through this process.
Can anyone guide me on whether this is possible, and if so, how I might configure DeepStream to send frames via MQTT using only configuration files, without diving into code? Any insights or suggestions would be greatly appreciated!
Please refer to “3.Send the image by the broker based on Kafka” in readme of ready-made sample /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test4/.
