All of the monitors in my house unfortunately do not have an HDMI port, but my laptop does. I was wondering if it was possible for me to do my startup using my laptop instead of a monitor, and if so, how could it be done? I have an SSD installed along with the Micro SD card. My Laptop has an HDMI port and VirtualBox with Windows 10 on it.
I doubt that this will work as HDMI ports on laptops are usually output-only for attaching an additional monitor.
In case one of your monitors has a DVI-D input you might have luck as HDMI signal is DVI-D compatible. Look out for a HDMI-to-DVI-D adapter, they usually cost around 10 bucks or less…
