Is it possible to use a Dahua IP camera with nvidia Deepstream?
Please chck if you can run the config file( overwrtie default test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt ) with kafkaserver:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=3
uri=rtsp://10.19.107.93:8554/test
num-sources=1
gpu-id=0
nvbuf-memory-type=0
# smart record specific fields, valid only for source type=4
# 0 = disable, 1 = through cloud events, 2 = through cloud + local events
#smart-record=1
# 0 = mp4, 1 = mkv
#smart-rec-container=0
#smart-rec-file-prefix
#smart-rec-dir-path
# video cache size in seconds
#smart-rec-video-cache
# default duration of recording in seconds.
#smart-rec-default-duration
# duration of recording in seconds.
# this will override default value.
#smart-rec-duration
# seconds before the current time to start recording.
#smart-rec-start-time
# value in seconds to dump video stream.
#smart-rec-interval
[source1]
enable=0
type=3
num-sources=1
gpu-id=0
nvbuf-memory-type=0
#smart-record=1
# 0 = mp4, 1 = mkv
#smart-rec-dir-path
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvoverlaysink 6=MsgConvBroker
type=6
msg-conv-config=dstest5_msgconv_sample_config.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM   - Custom schema payload
msg-conv-payload-type=0
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_kafka_proto.so
#Provide your msg-broker-conn-str here
msg-broker-conn-str=10.19.107.87;6789
topic=metromind-start
#Optional:
#msg-broker-config=../../deepstream-test4/cfg_kafka.txt
#new-api=0
#(0) Use message adapter library api's
#(1) Use new msgbroker library api's
[sink2]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
## only SW mpeg4 is supported right now.
codec=3
sync=1
bitrate=2000000
output-file=out.mp4
source-id=0
# sink type = 6 by default creates msg converter + broker.
# To use multiple brokers use this group for converter and use
# sink type = 6 with disable-msgconv = 1
[message-converter]
enable=0
# Name of library having custom implementation.
#msg-conv-msg2p-lib=<val>
# Id of component in case only selected message to parse.
#msg-conv-comp-id=<val>
# Configure this group to enable cloud message consumer.
[message-consumer0]
enable=0
conn-str=<host>;<port>
config-file=<broker config file e.g. cfg_kafka.txt>
subscribe-topic-list=<topic1>;<topic2>;<topicN>
# Use this option if message has sensor name as id instead of index (0,1,2 etc.).
#sensor-list-file=dstest5_msgconv_sample_config.txt
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=1
batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
nvbuf-memory-type=0
model-engine-file=../../../../../samples/models/Primary_Detector/resnet10.caffemodel_b2_gpu0_int8.engine
labelfile-path=../../../../../samples/models/Primary_Detector/labels.txt
config-file=../../../../../samples/configs/deepstream-app/config_infer_primary.txt
#infer-raw-output-dir=../../../../../samples/primary_detector_raw_output/
[tracker]
enable=1
tracker-width=600
tracker-height=288
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
#ll-config-file=tracker_config.yml
#ll-config-file=iou_config.txt
gpu-id=0
#enable-batch-process applicable to DCF only
enable-batch-process=0
[secondary-gie0]
enable=1
gpu-id=0
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=0;
batch-size=16
config-file=../../../../../samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt
labelfile-path=../../../../../samples/models/Secondary_VehicleTypes/labels.txt
model-engine-file=../../../../../samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
[secondary-gie1]
enable=1
gpu-id=0
gie-unique-id=5
operate-on-gie-id=1
batch-size=16
config-file=../../../../../samples/configs/deepstream-app/config_infer_secondary_carcolor.txt
labelfile-path=../../../../../samples/models/Secondary_CarColor/labels.txt
model-engine-file=../../../../../samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
[secondary-gie2]
enable=1
gpu-id=0
gie-unique-id=6
operate-on-gie-id=1
batch-size=16
config-file=../../../../../samples/configs/deepstream-app/config_infer_secondary_carmake.txt
labelfile-path=../../../../../samples/models/Secondary_CarMake/labels.txt
model-engine-file=../../../../../samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
[tests]
file-loop=0
You would need to modify the lines in [source0] per your IP camera:
type=3
and IP address of kafka server in [sink1]:
We set up the server by executing step 1 and 2 in:
// modify IP_Address:Port in config/serer.properties before executing step 2
listeners = PLAINTEXT://10.19.107.87:6789
I’m new to kafka and IoT protocols. What I understood is that I have to use 127.0.0.1 as the IP address of kafka server and with a port of 9092, is this correct?
my config file got like this:
[application]
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=3
uri=rtsp://admin:12345678W@192.168.1.108:554/cam/realmonitor?channel=1/subtype=1
num-sources=1
gpu-id=0
nvbuf-memory-type=0
#smart-record=1
# 0 = mp4, 1 = mkv
#smart-rec-dir-path
#smart-rec-duration
#smart-rec-interval
[source1]
enable=0
type=3
num-sources=1
gpu-id=1
nvbuf-memory-type=0
#smart-record=1
# 0 = mp4, 1 = mkv
#smart-rec-dir-path
[sink0]
enable=1
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=1
type=6
msg-broker-conn-str=127.0.0.1;9092
#Optional:
#new-api=0
[sink2]
enable=0
type=3
#1=mp4 2=mkv
container=1
codec=3
sync=1
bitrate=2000000
output-file=out.mp4
source-id=0
[message-converter]
enable=0
[message-consumer0]
enable=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=1
batch-size=1
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
#property
batch-size=1
interval=0
gie-unique-id=1
nvbuf-memory-type=0
[tracker]
enable=1
tracker-width=600
tracker-height=288
gpu-id=0
[secondary-gie0]
enable=1
gpu-id=0
gie-unique-id=4
operate-on-gie-id=1
batch-size=16
[secondary-gie1]
enable=1
gpu-id=0
gie-unique-id=5
operate-on-gie-id=1
batch-size=16
[secondary-gie2]
enable=1
gpu-id=0
gie-unique-id=6
operate-on-gie-id=1
batch-size=16
[tests]
file-loop=0
and in config/serer.properties before executing step 2 of the set up of the kafka enviroment, it’s set with:
listeners = PLAINTEXT://127.0.0.1:9092
Then I ran deepstream-test5-app:
$ ./deepstream-test5-app -c configs/test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
But got the same error as my previous answer:
** ERROR: <main:1451>: Failed to set pipeline to PAUSED
Quitting
ERROR from sink_sub_bin_sink2: Could not initialize supporting library.
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmsgbroker/gstnvmsgbroker.c(359): legacy_gst_nvmsgbroker_start (): /GstPipeline:pipeline/GstBin:sink_sub_bin2/GstNvMsgBroker:sink_sub_bin_sink2:
unable to open shared library
ERROR from sink_sub_bin_sink2: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Debug info: gstbasesink.c(5265): gst_base_sink_change_state (): /GstPipeline:pipeline/GstBin:sink_sub_bin2/GstNvMsgBroker:sink_sub_bin_sink2:
Failed to start
App run failed
You would need to set up the fafka server on another x65 PC, not on Nano. And put the IP address in the config file. In the example, 10.19.107.87 is the IP address of our kafka server. By default the port is 9092, we set it to 6789.
I set it up in another x64PC. But still getting the same error:
renan@renan-desktop:/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-test5$ ./deepstream-test5-app -c configs/test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
Quitting
Failed to start
App run failed
