According to Configuration File for Dataset Converter , the image_extension needs to be fixed to png, etc.
Is there any way to handle disparate extensions such as jpg, png, etc. in a comprehensive manner?
I would like to know how to convert images to Tfrecord in bulk, even if jpg and png are mixed in.
The “tlt-dataset-convert” does not support mixed extension format. You can transfer one kind of extension to another in order to unify the image format.
Thanks for the reply.
I will try to create my own script to change any image to tfrecord format which can be used in tlt training.
The format created by “tlt-dataset-convert” does not seem to be the common tfrecord format (.tfrecord) and does not have an extension.
Is it possible to check the code on github to see what “tlt-dataset-convert” is doing?
