I would like to know is it possible bellow explained algorithm in CUDA:
Given N points, I give each the cuda threads one point and have programming to find the local maxima about something object function in each thread.
Namely,
mycuda_kernelfunction(...) {
while(1) {
  1. given one point in this thread, find the next point to minimize the object function.
  2....N-1. something jobs...
  N. stop the while loop if some condition is true, otherwise continue.
Is it possible above the codes…
In this above codes, each threads will run respective difference(not equal) step. For example, some thread is processing at 2 step, another one is processing at 14 step, some of the others is processing at Nth step.
As I understood, SIMD is to be one single instructment multiple data, so the group threads in SMs(or warp) must be processing at the same steps. I am confusing these words and the concept of thread programming model in CUDA.
I think the above code is impossible under threads of the CUDA.
