Hi, please give me a hand…
Is JetPack 5.1.4 working for AGX Xavier? After I flashed JetPack 5.1.4, my AGX Xavier is working, but without GPU/CUDA.
I couldn’t even run the following command.
➜ sudo apt --fix-broken install
Reading package lists... Done
Building dependency tree
Reading state information... Done
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin dpkg-repack gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common libdebian-installer4 libtimezonemap-data libtimezonemap1 os-prober python3-icu python3-pam rdate
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
libnvidia-compute-535 libnvidia-extra-535 libnvidia-gl-535 nvidia-utils-535
The following NEW packages will be installed:
0 upgraded, 4 newly installed, 0 to remove and 1 not upgraded.
19 not fully installed or removed.
Need to get 0 B/209 MB of archives.
After this operation, 591 MB of additional disk space will be used.
Do you want to continue? [Y/n] ^C
Can anybody please help?
Thank you …
Cheers
