Looking for a compatible carrier board for the AGX Orin Industrial Model. Is there any available? Does the dev kit work with it?
The Orin industrial module is compatible with the Orin devkit.
You can also use the carrier board from our ecosystem partners, more information at Jetson Partner Hardware Products | NVIDIA Developer
That’s great! Thanks. The reason I ask is because connect tech boards are listed as compatible but are actually not compatible with the industrial version of the orin.
