Would like to know if Jetson Nano can be called as edge server. Since it has limited compute power and can handle multiple camera streams.
I’d call it an edge “device”. It isn’t really suitable for training AI, but it is quite good at processing images due to the GPU, including image recognition. Until you get to the higher end models the CPUs are lacking for general compute (even so they’re pretty good at that compared to many small embedded systems…RAM alone exceeds what many older microcontrollers have). You’d probably have to ask about a specific use-case to get a good answer.
