Is Jetson Nano vulnerable to Fusee Gelee exploit?
I have my board Jetson Nano P3450-Porg.
log info:
Tegra210 (P3450-Porg) # �[0007.979] Enabled early print
[0007.982] [TegraBoot] (version 00.00.2018.01-l4t-e5cfc6a7)
[0007.987] Processing in recovery mode
[0007.990] A02 Bootrom Patch rev = 1023
My question is:
Is this Tegra SoC vulnerable to Fusee Gelee or it has been fixed?
Regards
sk
Is the tegra SoC in Jetson Nano the same than Tegra SoC in Switch?
Thank you for your answer.
sk
No, still a bit different. Please refer to the module datasheet.
Hi kayccc,
different how please?
I read module datasheet and it refers to Tegra X1 (SoC) Technical Reference Manual all the time…
Regards
It would require local access even if it was, and in that case you’re already pwned. It’s not a remote exploit. You can always try the exploit and see if it works on the nano bootrom. more details
