Is Jetson TX2/TX1 Support psensor monitor CPU temperature ?
Hi zbit, running this works OK for me.
$ sudo apt-get install psensor
$ psensor
thank you first.
is jetson hardware support ?
Yes, the sensors reflect various temperatures on the Jetson hardware.
Additional note: One thing to be aware of is that killing the window of psensors doesn’t terminate the process.
In foreground you can send Ctrl-C for killing it, but if in background or launched from Ubuntu launcher, it is mandatory to use Quit in menu bar for a clean exit.
You may also use xsensors, it is less complete, but it doesn’t have this problem.
