• Hardware Platform (Jetson / GPU) T4
• DeepStream Version 6.4
• TensorRT Version
When I try to run a joint Action Recognition Net modeled that I trained using Tao I get an error. There seems to be discrepancies between TAO and Deepstream docs regarding whether it’s supported or not. If Joint models are supported, how do I deploy them? Below is my Deepstream config file.
# deepstream action recognition config settings.
# run:
# $ deepstream-3d-action-recognition -c deepstream_action_recognition_config.txt
[action-recognition]
# stream/file source list
uri-list=file:///app/videos/clip.mp4;
# eglglessink settings
display-sync=1
# 0=eglgles display; 1=fakesink
fakesink=0
# <preprocess-config> is the config file path for nvdspreprocess plugin
# <infer-config> is the config file path for nvinfer plugin
# Enable 3D preprocess and inference
preprocess-config=config_preprocess_3d_custom.txt
infer-config=config_infer_primary_3d_action.txt
# Uncomment to enable 2D preprocess and inference
#preprocess-config=config_preprocess_2d_custom.txt
#infer-config=config_infer_primary_2d_action.txt
# nvstreammux settings
muxer-height=720
muxer-width=1280
# nvstreammux batched push timeout in usec
muxer-batch-timeout=40000
# nvmultistreamtiler settings
tiler-height=720
tiler-width=1280
# Log debug level. 0: disabled. 1: debug. 2: verbose.
debug=1
# Enable fps print on screen. 0: disable. 1: enable
enable-fps=1
When I run it I get this error:
root@instance:/app# deepstream-3d-action-recognition -c deepstream_action_recognition_config_3d.txt
num-sources = 1
Now playing: file:///app/videos/clip.mp4,
0:00:07.944425681 132 0x55fc0bc2aca0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/app/models/joint_model_epoch019.engine
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_rgb 96x224x224
1 INPUT kFLOAT input_of 64x224x224
2 OUTPUT kFLOAT fc_pred 5
0:00:08.068822876 132 0x55fc0bc2aca0 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /app/models/joint_model_epoch019.engine
0:00:08.072453936 132 0x55fc0bc2aca0 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initNonImageInputLayers() <nvdsinfer_context_impl.cpp:1611> [UID = 1]: More than one input layers but custom initialization function not implemented
0:00:08.072477897 132 0x55fc0bc2aca0 ERROR nvinfer gstnvinfer.cpp:676:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1385> [UID = 1]: Failed to initialize non-image input layers
0:00:08.079001984 132 0x55fc0bc2aca0 WARN nvinfer gstnvinfer.cpp:898:gst_nvinfer_start:<primary-nvinference-engine> error: Failed to create NvDsInferContext instance
0:00:08.079021877 132 0x55fc0bc2aca0 WARN nvinfer gstnvinfer.cpp:898:gst_nvinfer_start:<primary-nvinference-engine> error: Config file path: config_infer_primary_3d_action.txt, NvDsInfer Error: NVDSINFER_CUSTOM_LIB_FAILED
Running...
ERROR from element primary-nvinference-engine: Failed to create NvDsInferContext instance
Error details: gstnvinfer.cpp(898): gst_nvinfer_start (): /GstPipeline:preprocess-test-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
Deleting pipeline
