Hi
When I tried to use mclock() in PGI fortran,
it complains “: error S0038 : Symbol, mclock, has not been explicitly declared”. Do we need to include any module for this to work?
I tried to use system_clock() as an alternative for the timer:
program prog
implicit none
integer :: pstart, pend, i,a, j
integer :: nprocs, hz, clock0, clock1
real :: time
integer :: t
call system_clock (count_rate=hz)
call system_clock(count=clock0)
do i = 1,100000
write(*,*), ' '
end do
call system_clock(count=clock1)
t = (clock1 - clock0)
time = real(t) / real(hz)
write(*,*) 'time = ',time
end
But it is giving output 0.0000 always, but this is running for few seconds for sure. Any error in the code above?
Thanks in advance.
