I am thinking of using NVidia Jetson AGX Xavier for a robotics application. The Camera is a 3D Camera (data format very similar to as Intel RealSense Depth Camera D415 but the interface is Ethernet.
Max throughput for one camera with 2 streams :
・RGB 1280x720 @30 FPS
・Depth 1280x720 @30 FPS
RGB = 1280 x 720 x 30 x 16 bit = 442,368,000 bits
Depth = 1280 x 720 x 30 x 16 = 442,368,000 bits
Total max throughput for 1 camera with 2 streams = 884,736,000 bits
Question 1:
Will AGX Xavier Gigabit Ethernet interface be able to handle this throughput requirements?
Question 2:
Since I need to use 2 POE Cameras and since Xavier has only one ethernet interface, I was thinking of USB 3.1 to Ethernet bridge and cpnnecting another camera over there. Will USB 3.1 to Ethernet converted interface be able to handle this throughput requirements?
Warm regards,
Koustubh Thorat
