My goal is to use Jetson Xavier NX module with Jetson Nano Developer Kit B01.
The problem is that the Jetson Xavier NX module itself is already expensive and I can’t find seller that only sell the Jetson Xavier NX Developer Kit.
Is it compatible?
Is it compatible?
Yes, Nano and Xavier NX module are pin compatible/
You can also check: Considerations when using Jetson Xavier NX module with Nano devkit carrier - Jetson & Embedded Systems / Jetson Xavier NX - NVIDIA Developer Forums
