Hi
I can use OpenCV VideoCapture to launch the gstreamer script below to carry out the image processing and streaming video to other device with WIFI connection.
"v4l2src device=/dev/video0 \
! video/x-raw, format=UYVY, width=2592, height=1944, framerate=24/1 \
! nvvidconv ! video/x-raw(memory:NVMM), format=I420 \
! tee name=camNVMM ! queue ! nvv4l2h264enc maxperf-enable=true insert-vui=true insert-sps-pps=1 bitrate=10000000 control-rate=1 vbv-size=625000 \
preset-level = 1 MeasureEncoderLatency=1 \
! h264parse ! rtph264pay ! udpsink clients=192.168.18.18:38298 \
camNVMM. ! queue ! nvvidconv ! video/x-raw, format=GRAY8, width=640,height=480 ! appsink"
The video streaming is using UDP. When tried to stream the video to other device using RTSP,
I tried the code below:
./test-launch "v4l2src device=/dev/video0 \
! video/x-raw, format=(string)UYVY, width=(int)2592, height=(int)1944,framerate=24/1 \
! nvvidconv \
! video/x-raw(memory:NVMM),format=(string)I420 \
! tee name=camNVMM ! queue ! nvv4l2h264enc preset-level=1 MeasureEncoderLatency=1 maxperf-enable=true insert-vui=true insert-sps-pps=1 bitrate=10000000 control-rate=1 vbv-size=625000 speed-preset=ultrafast \
! h264parse ! rtph264pay name=pay0 "
I can get the RTSP video from other WIFI connected device.
The issue is that how can I get the video frame from
by using OpenCV VideoCaptued) for my image processing?
CX
