Is Orin currently unable to use JetPack5.0.2
flash error
    • [ 5.6197 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
      [ 5.6212 ] BL: version 0.23.0.0-t234-54845784-92215740 last_boot_error: 0
      [ 5.6509 ] Sending bct_mem
      [ 5.6994 ] Sending blob
      [ 5.7527 ] ERROR: might be timeout in USB write.
      Error: Return value 3
      Command tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
      Failed flashing t186ref.
      [0017.559] I> BCH address is : 0x40050000
      [0017.563] I> MEM-BCT-0 header integrity check is success
      [0017.568] I> Binary magic in BCH component 0 is MEM0
      [0017.573] I> component binary type is 0
      [0017.578] I> MEM-BCT-0 binary is read from storage
      [0017.583] I> MEM-BCT-0 binary integrity check is success
      [0017.588] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
      [0017.595] I> RAM_CODE 0x4000011
      [0017.600] I> RAM_CODE 0x4000011
      [0017.604] I> Task: Load Page retirement list (0x50011139)
      [0017.609] I> Task: SDRAM params override (0x50011b79)
      [0017.614] I> Task: Save mem-bct info (0x50014071)
      [0017.619] I> Task: Carveout allocate (0x500140d5)
      [0017.623] I> ECC region[0]: Start:0x0, End:0x0
      [0017.628] I> ECC region[1]: Start:0x0, End:0x0
      [0017.632] I> ECC region[2]: Start:0x0, End:0x0
      [0017.636] I> ECC region[3]: Start:0x0, End:0x0
      [0017.640] I> ECC region[4]: Start:0x0, End:0x0
      [0017.645] I> Non-ECC region[0]: Start:0x80000000, End:0x80000000
      [0017.651] I> Non-ECC region[1]: Start:0x0, End:0x0
      [0017.655] I> Non-ECC region[2]: Start:0x0, End:0x0
      [0017.660] I> Non-ECC region[3]: Start:0x0, End:0x0
      [0017.664] I> Non-ECC region[4]: Start:0x0, End:0x0
      [0017.675] E> BL_CARVEOUT: Failed to allocate memory of size 0x36800000 for CO:.
      [0017.682] C> Task 0x0 failed (err: 0x49490003)
      [0017.686] E> Top caller module: BL_CARVEOUT, error module: BL_CARVEOUT, reason0
      [0017.695] I> Busy Spin
Please do not use this old version of BSP anymore. Go to use latest one and you will get it flashed.
