Is OTA update from 35.4 to 35.5 possible for the Orin Nano?
Have been reading documentation that is a bit conflicting and wanted to know if this is possible. I have found this image below, but on the website some documentation says OTA is only supported for Jetson Xavier or Jetson AGX
Hi isiah.lashley,
Yes, it is supported.
Are you using the devkit or custom board for Orin Nano?
Do you enable disk-encryption or rootfs redundancy (a/b) in your case?
Yes, I am using the devkit for the Orin Nano with both disk-encryption and rootfs redundancy
Yes, they are supported on Orin Nano.
Please confirm that both disk-encryption and rootfs a/b are enabled before update (R35.4).
Then, you can perform image-based OTA update to R35.5.
Okay, thank you for the clarification. Does this also work with SecureBoot enabled?
Secureboot is supported, but UEFI secureboot is not support.
i.e. you can specify PKC/SBK key during generating OTA package.
