Hi all,
we are testing a Qt Quick Scene with some GStreamer streams. It runs fine on a Host Machine. As sink we are using a ‘qmlglsink’. If we try to run it on the Jetson, we get an error:
GST_ELEMENT_FACTORY gstelementfactory.c:457:gst_element_factory_make: no such element factory “qmlglsink”
The packages for plugins-good and plugins-bad are installed properly. But the ‘qmlglsink’ isn’t listed when running gst-inspect.
I crawled a bit through the packages and it seems as this simply isn’t listed there.
From the versioning it should be included in the plugins-bad package at least.
Gst-Launch --version is showing GStreamer-Version 1.8.3.
On this page: Release notes for GStreamer Bad Plugins 1.8.3 "" it seems as the qmlglsink should be included in plugins-bad at least with this version.
Our system is:
Linux JetsonTX1 4.4.38-tegra #1 SMP PREEMPT Thu Mar 1 20:44:58 PST 2018 aarch64 aarch64 aarch64 GNU/Linux
I also tried updating the packages and upgrading the plugins-good and -bad, but without success.
Does anyone have some insights here? Maybe the qmlglsink is left out for some reason on the ‘Nvidia’-Ubuntu? Or there is some other version / package mismatch?
Thanks,
Bodo
