In the channel.c driver , we’re using the tegra_channel_buffer_prepare()
function to manage buffers and track the framecount
variable. I believe this function is invoked when a buffer is being enqueued. Can anyone confirm if tegra_channel_buffer_prepare()
is specifically triggered during the enqueue process, and if it’s the correct place to capture and track the current frame count?
hello abraham.s,
it means this buffer has been prepared.
may I know what’s the real use-case? you may tracking the vbuf->sequence
as following.
note, vb2_buffer_done
is the function call for sending a frame to user-space.
for instance, $public_sources/kernel_src/kernel/nvidia/drivers/media/platform/tegra/camera/vi/vi5_fops.c
static void vi5_release_buffer(...)
vbuf->sequence = chan->sequence++;
vb2_buffer_done(&vbuf->vb2_buf, buf->vb2_state);
I want to obtain the frame id from the embedded metadata and that to from enqueue buffer. Is it possible to obtain that value during the enqueuing process
hello abraham.s,
there’s capture_descr_index
, an index into the VI capture descriptor queue.
