**• Hardware Platform (GPU) RTX 3060
**• DeepStream Version 6.1.1 • TensorRT Version
**• NVIDIA GPU Driver Version (valid for GPU only) CUDA11.7
When I run deepstream_nvof_test.c, it output dense optical flow, any suggestions if I want to output sparse optical flow. As there is no nvof plugin, so can’t direct change optical flow algorithms from source code, so where should I change the optical flow algorithm to get sparse optical flow?
Thanks for the reply. I have to questions to double:
1.Is that possible we change the nvof internal optical flow algorithm. As I want optical flow motion vectors (sparse optical flow).
2.As in deepstream 6.1.1, there is only test code in deepstream-nvof-test, how to extract the optical flow ,as there is no source code in plugin for gst-novf.
There is no update from you for a period, assuming this is not an issue any more. Hence we are closing this topic. If need further support, please open a new one. Thanks
