Is the fix a simple one-liner?
Since July, I’ve been quietly annoyed at the default Dashboard reporting erroneous updates to firmware.
I’m here:
But the Dashboard reports this:
Can someone please suggest a way to resolve the discrepancy?
Thanks in advance!
I don’t have this problem. Perhaps one of your previous updates was interrupted
If you’re not running the Nvidia FE and instead have one of the OEM models, likely your OEM hasn’t provided updated firmware yet. I have one Nvidia DGX Spark and two Asus GX10’s. The GX10’s still don’t have the same firmware parity that the July 2026 update round requires. The Spark already has the July updates.
@Railinski open a terminal and run sudo apt autoremove to uninstall old nvidia-firmware packages. Run apt list --installed nvidia-firmware* to see how many version are installed on your system.
Thank you for the suggestion. The User Manuals from each manufacturer of our accelerated computing boxes, all stress that updates occur via the Dashboard rather than typical CLI package/firmware management avenues. I’ve held off deviating from this dictate. It just so disappointing that the recommended path is fragile, lacks transparency, and for myself- can’t be trusted.
DGX Dashboard issues like these should have been fixed last week. Please let me know if you see any other issues after updating.
