Is the frame_meta->obj_meta_list is ordered by some parameter and is it possible to configure the sort
The object list returned per frame frame_meta->obj_meta_list. Is it sorted by bbox or class id or anything?
If we have to customize the order, what will it be?
• Hardware Platform (Jetson / GPU): Both
• DeepStream Version6.2
• TensorRT Version
No. You can refer to the open source code: attach_metadata_detector in gstnvinfer_meta_utils.cpp. Once an object is detected, we will attach it to the glist. If you want to customize it, you can read that from the obj_meta_list and sorted yourself.
