Is the PCB of TX1 certified UL94 V0
Dear,
Is the PCB of the TX1 jetson module certified UL94 VO (for inflammability)? Can you furnish the certificate?
Best,
Joël Chavas.
Hi jchavas,
We don’t have flammability cert but our PCB is UL94 V0 certified.
Dear,
we abstolutely need to prove this point to the regulatory autorities.
Can you give us at least the certificate number or the report number proving that the PCB is UL94 V0?
Thanks in advance,
best,
Joël Chavas.
Hi, here is the datasheet for the material, FYI. [url]http://www.emctw.com/upload/website/products/EM-370(5)DM-web.pdf[/url]
Thanks,
it helps. At a last request, can you give the UL file number of the PCB, starting from “E…”. It is given usually by the PCB manufacturer. If you have the certificate of the PCB produced (given by the PCB producer), this is better. Otherwise, the UL file number is sufficient,
thanks for your effort,
best,
Joël Chavas.
Dear,
if you can’t provide this, can you give the certificate of conformity of the PCB proving that is it UL94 V0?
Thanks in advance,
Joël Chavas.
Hi, we are checking and will update it later if possible, thanks.
Dear,
do you have any update on this?
If you don’t have any, can you give us at minimum the name of the PCB producer?
Best,
Joël.
Sorry for missing this, the material is EM-370(5).
