In the next flash process I added the BootOrderEmmc.dtbo as an overlay and hoped that it would by default boot from the SD card too then.
That unfortunately does not work. Is there an overlay I can use to make it boot from SD Card again?
I tried this with Xavier NX SD Version on the devkit.
I decompiled the dtbo and wrote my own with boot order overlay sd,emmc,nvme and called it BootOrderInternal.dtbo. Will try if that works and report back.
You can use your own overlay with the following content to prefer internal boot to nvme if you previously flashed an nvme and want to go back to emmc or sd card:
