Are there performance differences between JetPack 5.1.5 and JetPack 6.2 in super mode? For example, CPU frequency, GPU frequency, or RAM frequency, or any other differences?
To answer your question, we need to compare the performance differences between JetPack 5.1.5 and JetPack 6.2 in Super Mode for Jetson Orin Nano.
Unfortunately, the provided context does not explicitly mention the performance differences between JetPack 5.1.5 and JetPack 6.2 in Super Mode. However, we can infer some information from the context.
The context mentions that Jetson Orin Super Mode is enabled via software upgrade and requires a higher power budget. It also mentions that the new flash configuration file supports a 25W power mode and MAXN power mode for the Jetson Orin Nano series.
In the context, there is a table that shows the NVP Model Clock Configuration for Jetson AGX Orin 32GB. Although this table is not directly related to Jetson Orin Nano, it gives us an idea of how different modes can affect the performance of the device.
The table shows that different modes have different power budgets, CPU frequencies, GPU frequencies, and DLA core frequencies. For example, the 15W mode has a lower CPU frequency (1113.6 MHz) compared to the 40W mode (1497.6 MHz).
Assuming that a similar configuration applies to Jetson Orin Nano, we can infer that the performance differences between JetPack 5.1.5 and JetPack 6.2 in Super Mode might be related to the power budget, CPU frequency, GPU frequency, and RAM frequency.
However, without explicit information about the performance differences between JetPack 5.1.5 and JetPack 6.2 in Super Mode, we cannot provide a comprehensive comparison.
To answer your question accurately, we would need more information about the specific performance differences between JetPack 5.1.5 and JetPack 6.2 in Super Mode for Jetson Orin Nano.
In summary, while we can infer some information about the potential performance differences between JetPack 5.1.5 and JetPack 6.2 in Super Mode, we do not have enough information to provide a comprehensive comparison.
The super mode starts from JetPack 5.1.5 and JetPack 6.2, all essential configurations for the highest number of cores and clock frequency for CPU, GPU, DLA, PVA…etc are the same settings.
Okay, thanks
