I want to make sure I get the correct isolation/filtering magnetics designed in but the design guide only shows the example for Power Over Ethernet. Can someone point me to a reference design without PoE?
Hi, you should refer to the magnetics data sheet for that.
Can you be more specific, such as provide a link up am example, or a reference design that does not use PoE?
Did you check the P3768_A04 schematic for detail? What kind of RJ45 connector is used on your board?
Are you using a separated magnetics component? If so, we don’t have such example. You should check with the magnetic vendor for its reference design. On Orin NX side, it is just the same GBE port no matter with or without PoE.
