Is there a systemd command which mimics the run level 3 (networking with no X-windows)?
" You should also set the default run level on your system such that it will boot to a VGA console, and not directly to X". —> this is from the README file and for using the NVIDIA*run script build a 470 driver.
And is there a systemd command which mimics going to run level 5 from this VGA console state (A.K.A run level 3 in inittab terminology?
Use
systemctl isolate
e.g.
systemctl isolate multi-user.taget
for RL3
systemctl isolate graphical.target
for RL5
systemctl get-default
to display default target
systemctl set-default
to set default target
on kernel cmdline:
systemd.unit=multi-user.target
IIRC, e.g. “init 3” still works for backwards compatibility but not sure about this.
