Dear:
Is there a torque requirement for securing the copper plate to the module for heat dissipation?
Based on the photo, it appears that you are using a Jetson Orin Nano or Orin NX module with a custom-designed heat spreader.
NVIDIA does not provide a specific torque specification for custom thermal solutions, as the appropriate torque value depends on several factors specific to your design:
We recommend starting with a low torque and gradually increasing while monitoring TIM squeeze-out and thermal performance, to find the optimal torque for your specific design.
Also, we recommend tightening screws in a cross (X) pattern in multiple passes (e.g., 50% → 75% → 100% of target torque) rather than fully tightening one screw at a time, to ensure even TIM compression and prevent warping of the module or heat spreader.
