Is there a way to configure a Jetson TC2 from another Jetson TX2?
I understand that the Jetpack “run” application has to be run on a 64bit Intel based Linux machine to flash the TX2.
Once I have done that for a Jetson TXC2 devkits, is there a way to configure a different Jetson TC2 from that TX2?
After you run JetPack from the x86-based host PC to flash and complete the post-install steps (when JetPack installs packages on the Jetson over SSH), then you are free to connect to the Jetson from other machines (presumably over SSH). Just put both Jetson’s on the same network and login via SSH or map the disk with sshfs, then you can make any configuration changes to the root image remotely.
Thank you!
