Jetson Nano
• DeepStream Version
5.0.1
4.5 (latest SD image)
• TensorRT Version
I’m having a question regarding the config entry model-engine-file
. I’m having a configuration, in which I can use up to three cameras, dynamically from the command line, as in the Python “test-3” sample with the files.
As like with the files I’m programmatically change the batch-size
parameter according to the found sources (so 1 for one, 2 for two and so on).
This seems to clash with the fixed entry in the config, which always points to just one specific file., e.g./home/neil/jetson/models/primary-detector-nano/resnet10.caffemodel_b1_gpu0_fp16.engine
If now for instance this file was produced with (as the name “b1” says) batch-size 1, everything is OK and the engine loads it and boots up fast, if I start it with one source only. But if I start it with for instance 3 sources, the entire file is re-constructed, which slows down the start (and sometimes also causes a crash).
Is there a way to programmatically configure the engine file w/o having to adapt the config file all the time depending on the number of inputs?
I could als omit the dynamic change of the batch-size, but I don’t know about the consequences.
