The documentation for SightWidget mentions that one can set name
and active
for channels. I’ve discovered that it also accepts color
using html color codes (e.g., #ffeeaa
). Is there also a way to specify the opacity? I’ve already tried using other HTML color formats that include alpha, and also tried adding a field “opacity”, but nothing worked.
SightWidget
itself does not expose the channel opacity as a parameter, but you should be able to bake the opacity into the color string: “#RRGGBBAA”.
