DRIVE OS Version: 7.0.3
Issue Description:
Is there a way to connect a PCIe device over the MiniSAS connectors such as an IcyDock Mini-SAS enclosure?
The use case is to connect high speed external storage to the Thor Drive AGX dev kit for logging raw camera data from multiple sensors and a USB-C connection does not have the bandwidth to support multiple raw feeds simultaneously, nor is a good connector for staying securely connected in a moving vehicle.
We have tried updating the device tree to enable controller C5 per the SDK docs (which is connected to Port 1 per the mechanical and installation guide) and did see a new PCIe device show up in the device tree when running lspci, however connecting an IcyDock on both the external MiniSAS connectors showed no device negotiation attempts as if nothing was connected. We used a Mini SAS HD SFF-8644 to mini SAS HD SFF-8643 cable (like this one) to connect the two devices.
We saw in the mechanical installation document that the only documented use case to connect something to those external PCIe connectors is for Thor to Thor communications and that “Standard PCIe Mini-SAS cables will NOT work” - however, is that only for the Thor-to-Thor communications use case that a standard PCIe Mini-SAS cable would not work? I would expect having all the documentation to configure the PCIe controllers in the device tree means that there are other use cases aside from the Thor-to-Thor communications feature.
Related, can we confirm that the C5 and C4 PCIe controllers are what is connected to Port 1 and Port 2 on the outside of the dev kit?
Thank you for your assistance.
