Vulkan is able to import host memory using VkImportMemoryHostPointerInfoEXT
. I queried the supported memory types for VK_EXTERNAL_MEMORY_HANDLE_TYPE_HOST_ALLOCATION_BIT_EXT
on an RTX 2060 but the only kind of memory that was available for it was coherent, which does not work for my use case. The memory needs to use explicit invalidations/flushes for performance reasons. So really, I don’t want the API to allocate any host-side memory, I just want to tell it the base address that the buffer should upload from/download to. Otherwise I have to use intermediate copies. Using the address returned by vkMapMemory for the host-side work is not desirable for my use-case. Am I doing this the wrong way or is this just not possible?
