Jetson Xavier NX • DeepStream Version
DeepStream 6.0 • JetPack Version (valid for Jetson only)
4.6.1-b110 • TensorRT Version
8.2.1.8
I am using pruned PeopleNet. To confirm if the program works correctly, I run it and it takes a couple of minutes to create the engine from the model. Is there any way to shorten the time in order to check the result soon? Thanks in advance.
Do you have model-engine-file set in your pgie config? The engine specified by model-engine-file will be created if doesn’t exist, and then it can be reused. Or you can create engine file from tensorrt and use it directly.
@yingliu thank you for your response. Yes, here is the config
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
tlt-model-key=tlt_encode
tlt-encoded-model=../../../../samples/models/tao_pretrained_models/peoplenet/resnet34_peoplenet_pruned.etlt
labelfile-path=../../../../samples/configs/tao_pretrained_models/labels_peoplenet.txt
model-engine-file=../../../../samples/models/tao_pretrained_models/peoplenet/resnet34_peoplenet_pruned.etlt_b1_gpu0_fp16.engine
input-dims=3;544;960;0
uff-input-blob-name=input_1
batch-size=1
process-mode=1
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=3
cluster-mode=1
interval=0
gie-unique-id=1
output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid
[class-attrs-all]
pre-cluster-threshold=0.4
## Set eps=0.7 and minBoxes for cluster-mode=1(DBSCAN)
eps=0.7
minBoxes=1
[class-attrs-1]
# disable bag detection
pre-cluster-threshold=1.0
in …/…/…/…/samples/models/tao_pretrained_models/peoplenet directory, I don’t have resnet34_peoplenet_pruned.etlt_b1_gpu0_fp16.engine. How do I create and keep?
Thank you sooo much! As you told, I ran the command with sudo and the engine file was created in the directory, and the program became to start quickly.
