Is there a way to use only RE-ID score in deepsort-tracker?
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.0.1 devel
• TensorRT Version 8.0.1
• NVIDIA GPU Driver Version (valid for GPU only) 11.7
• Issue Type( questions, new requirements, bugs) new requirements, bugs, questions
Hello
According to the Deepsort paper (https://arxiv.org/pdf/1703.07402.pdf)), the performance was excellent when only re-id was used (lambda=0, Except for Kalman), So can I use only re-id with Kalman motion turned off?
Here is the Data Association used in DeepStream DEEPSORT tracker:
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_plugin_gst-nvtracker.html#id3
Thank you for your answer
But I don’t think that’s a clear answer. There’s no place to turn off a score about Kalman Motion anywhere.
Can you check config_tracker_NvDeepSORT.yml in your system? I am not sure if stateEstimatorType = DUMMY is what you need.
Apart from what you said, DeepSort tracking_confidence metadata basically comes out to 1 always…
Are you running deepstream-app? Can you share the reproduce step?
If the tracker algorithm does not generate confidence value, then tracker confidence value will be set to the default value (i.e., 1.0 ) for tracked objects. For IOU, NvSORT and NvDeepSORT trackers, tracker_confidence is set to 1.0 as these algorithms do not generate confidence values for tracked objects. NvDCF tracker, on the other hand, generates confidence for the tracked objects due to its visual tracking capability, and its value is set in tracker_confidence field in NvDsObjectMeta structure.
