May be it’s not that CUDA question but it’s really related to CUDA computations.
As I want to monitor GPU temperature while running CUDA kernels and stop them if things goes bad (GPU overheated or fan stopped, for example). For ATI’s GPUs there is a SDK called ADL which provide easy way to read such information (temperature, fan speed, min/max rpm, etc). Is there something similar for nVidia’s GPUs? The only thing I’ve found so way is “NvCplGetThermalSettings” @ nvcpl.dll but doesn’t looks like it works under Vista 64.
Under Linux you can use the command: “nvidia-settings” which provide some useful informations.
I think that should be something similar under Windows (maybe nvidia-ntune if you have an nvidia motherboard).
i dont know cuda but gpu-z monitors temperatures, rivatuner is much more advanced and you can create fan profiles to match temperatures and you can display a screen overlay as well.
Actually I’ve started with RivaTuner and RTHMSharedMemory sample. But it’s way too advanced – RT required unsigned driver installed for Vista64 and can’t work with 4770 & Catalyst 9.9. There probably more problems with such tools while I only need to read GPU(s) temperature, nothing more. So I’m happy now with ADL & nvapi.
