I’m use Warp&Blend to get seamless and blended display. But it takes a long time, and screen flickers. Is there any solution to reduce time and not to flicker.
Thanks,
Minghe
Thanks,
Minghe
I’ve seen that flicker and found it depends on the output devices, not the code.
That is – when running the same warp and blend code on similar Quadro cards (M2000, M4000) I see very long delays and flickering with the former and only a very short flicker (1/8" second with the latter).
In the former case, I’m using DisplayLink->HDMI connectors to low resolution projectors; in the latter case (the one that works well), it’s DisplayLink direct from the GPU to the projectors.
